I need to configure our Cisco Aironet 1200's for multiple VLANs. VLAN101 is for public use & VLAN2 is for employees only. Existing config is attached.
I need:
1. To disable the broadcast of VLAN2's SSID so that only VLAN101 shows up in the SSID list for visitors. Right now both are showing up.
2. To ensure the WEP key is setup correctly for VLAN2
Thanks in advance for your help!
