Multiple webauth login pages per wlan
I know you can use the global override feature on each WLAN to assign a specific login page.  The problem is how do you upload multiple login pages to the controller?  I have 2 wlans and created 2 webauth bundles (login.html, aup.html, logo.jpg).  Tried tarring them as wlan1.tar and wlan2.tar.  I can upload these individiually to controller but only 1 remains when I try and use the WLAN override feature.
I have also tried renaming the files (login1.html, aup1.html, logo1.jpg) and (login2.html, aup2.html, logo2.jpg) then uploading the 2 tar files again.  Same result.
Tried tarring them all together and the controller says "error extracting files".
Anyone got multiple login pages per wlan working?
Controller version 7.0.98.0
1 REPLY
Re: Multiple webauth login pages per wlan
Nevermind.  I sorted it myself.
For anyone interested I had to also upload a login.html page within the tar.  So I had for WLAN1 (login1.html, aup1.html, logo1.jpg) and for WLAN2 (login2.html, aup2.html, logo2.jpg) and also login.html all within the same .tar file.
311
