Multiple WLANs pointing to same WLC interface
I would like to have a guest Web auth based WLAN that points to an Interface that I also have configured for a separate 802.1X authentication that allows access to my private network.  I should note that I already have web auth configured for Guest access that only allows Internet access via separate WALN/VLAN.  This would allow me to setup access for a vendor that is on-site using the Lobby Ambassador .
Is this possible and what do I need to do?   I have created the seperate WLAN with Web auth and pointed it to the same WLC interface that I use for the 802.1X and this does not seem to work.
1 REPLY
This has been resolved.  I found I had AP groups setup and had not added the WALN to the correct group.
218
