NCS 1.1.1.24 & 5508 WLC v7.6
Hi all,
I have been told that NCS 1.1.1.24 officially does not support the latest WLC code 7.6 and that we have to upgrade to Prime Infrastructure 2.1.
Is anyone managing any WLC's running 7.6 with NCS 1.1.1.24 ? If so, does it work and are there any noticable features that do not work correctly?
Mario
  • Security and Network Management
Yes the recommended Prime
Yes the recommended Prime versions are 1.4 / 2.0/2.1 ,the current NCS version will not support WLCv6
Are there any additional
Are there any additional licence requirements to upgrade from 1.1.1.24 to 2.1 as I have a customer with the same issue and need to upgrade a couple of NCS appliances running in HA mode.
Gold
Cisco Prime Infrastructure 2
Cisco Prime Infrastructure 2.1 Major Release Upgrade Part Numbers for Existing Cisco Prime Infrastructure 1.x Customers:
http://www.cisco.com/c/en/us/products/collateral/cloud-systems-management/prime-infrastructure/guide-c07-731621.html
The customer has purchased
The customer has purchased the required licences but when I upgrade do I need to register and install them on the primary appliance or can I just upgrade the appliance from version 1.1 to 2.1 with the existing licence files on the box.
install license first and
install license first and them upgrade
Hi all,sorry, but my real
Hi all,
sorry, but my real question is...
I do not really want to upgrade NCS to Prime as we have not had it long! And I do not want to pay for a whole new solution to manage my Wireless.
Mario
Hi Mario,I am not managing
Hi Mario,
I am not managing controllers on 7.6 with 1.1.1.24 personally but I would expect that the controllers can be added to NCS but would then start throwing up errors. See the compatibility matrix at
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-148410
for the correct code versions supported by NCS and Prime.
Barry
I will see if I can lab this
I will see if I can lab this up either this week or next.
i will report back with any findings.
I really dont want to have to spend money upgrading to prime simply because Cisco want us to.
Mario
52
