NCS 1.1 not showing any access points
  I have NCS 1.1 appliance and added a 5508 WLC running 6.0.199.4 code using snmpv3. Controller is added to NCS, but it doesnt show any AP's which are there on the controller. AP count is zero. I have another controller with code 7.0.230 added and showing AP's though. AP model is 1252. Any idea why this might be ?
regards
Joe
Hall of Fame Super Gold
Re: NCS 1.1 not showing any access points
Your WLC controller.
hi Leo,
  I think you didnt complete your reply
regards
Joe
Hall of Fame Super Silver
Leo is suggesting that your wlc isn't sending the info. Have you tried to remove and add the wlc again? NCS dies support that code version on the wlc, but you never know.
-Scott
Yes, i guess the WLC isnt sending the info about AP's... is there anyway to debug that ?
yes tried removing and adding the WLC again, but same result.
1.  Make it simple:  Try SNMPv2 first.
2.  IF SNMPv2 doesn't work, upgrade your firmware to 7.0.235.0 or 7.2.110.0.
415
