NCS PI 1.3 - disk space for backups
Hi all!
We have an Prime-appliance and since a while back backups will not run because of what I think is a disk space issue.
The backups run locally and is then sent to remote ftp-server. But they only run for a few seconds and then change status to "failure".
I found this in the syslog:
Nov  1 11:27:03 172.21.248.36 11/01/13 11:27:03.649 INFO  [aesDatabase] [Execute Now-3] Repository name ftp-backup-repo-name
Nov  1 11:27:03 172.21.248.36 11/01/13 11:27:03.655 INFO  [aesDatabase] [Execute Now-3] PollWCSBackup: Free localRepoSpace Mb 51086
Nov  1 11:27:03 172.21.248.36 11/01/13 11:27:03.690 INFO  [aesDatabase] [Execute Now-3] PollWCSBackup: total DBSize Mb =  170525
Nov  1 11:27:03 172.21.248.36 11/01/13 11:27:03.691 INFO  [aesDatabase] [Execute Now-3] PollWCSBackup: Expected LocalBackupSize Mb =  56841
Is "Free localRepoSpace Mb 51086" located on the NCS server? If yes, where is that space located on the server?
On the other hand I could also read it like its a check of the free space on the ftp-repository.
Can someone enlighten me where I´am about 5.5 GB short? :-)
Thanks!
Hall of Fame Super Silver
Re: NCS PI 1.3 - disk space for backups
Your correct about that being the local repo free or available space. Your overall disk space has to be able to generate the backup and to compress it prior to sending it to an external repository. You need to just add an additional disk if your NCS is a VM.
This link will explain the low disk space message and also how to mount a drive.
https://supportforums.cisco.com/docs/DOC-26960
-Scott
Thanks Scott!
No its not a VM, its Cisco appliance.
My guess is you're keeping too many copies of backups in the local repository...the default is 7.
Go to Administration>Background tasks then see how many copies you're keeping on the local repository.
If 7, reduce the number to a lesser value then remember to delete extra copies.
Hey, if you're 1st writing to a local repo then are sending to an ftp server via a script or manual process, why not just change the backups to write to the remote ftp server?  All ya' gotta do is create an ftp repo then change Administration>Background Tasks>NCS Server backups to write to there.
Thanks for the input!
Sorry I was a bit unclear. I have configured a ftp-repo on the NCS-server, which is the remote ftp-server. But as I have come to understand, the backup process on the NCS-server is configured (and not possible to change) to first make the backup locally and then send it to the ftp-repo. Because I have checked the ftp-server side and the ftp transfer does not start when the backup job starts.
So I have no script or manual process for the ftp transfer.
Regarding saved backups, there is no old saved ncs backups on the NCS-server.
Configure the remote ftp repo from the cli like is shown in the 1st image.
Once the repo is configured then go to the GUI under Administration>Background Tasks>NCS Server backup then that repo will appear as one of the available repos to write to. Also shown as 2nd image
When the backup kicks off, you won't see the file appear over on the ftp server  until well into the process and the file won't get copied over until near the end of the process.
Silver
311
