NCS Prime prompting for login and password after re-imaging from dvd
Dear All,
I did a re-imaging on NCS prime after which I'm getting the below error
Please help me as to what could be the reason for this error...
Please type 'setup' to configure the appliance
localhost.localdomain login: Setup
Password:
Waseq Mohammed
Follow the process from
Follow the process from here
http://www.cisco.com/c/en/us/td/docs/wireless/ncs/appliance/install/guide/primencs_qsg/primencs_qsgmain.html
Re-imaging was not successful
Re-imaging was not successful try this process:
Restoring the NCS Database
If you are restoring the NCS database in a high availability environment, see the "Restoring the NCS Database in a High Availability Environment" section. To restore the NCS database from a backup file. follow these steps:
Step 1 To view all local repository backups, use the below command:
show repository backup_repo
Note If possible, stop all NCS user interfaces to stabilize the database.
Step 2 Manually shutdown the platform as root.
Step 3 Using the CLI, perform one of the following:
Restore the appliance and application backup by entering the following command:
restore testbackup-yymmdd-xxxx.tar.gpg repository backup_repo
Restore only the application backup by entering the following command:
restore testbackup-yymmdd-xxxx.tar.gpg repository backup_repo application NCS
Step 4 Click Yes if a message appears indicating that NCS is running and needs to be shut down.
Note If the restore process shuts down NCS, a restart is attempted after a successful restore. The appliance will then restart and you will have to again login and restart the dbserver, and the platform manually as root (make sure you do not start with dbclean, else you will loose your recently restored data).
The CLI displays messages indicating that the NCS database is being restored.
44
