NCS problem with global AP search
I am having this problem with my NCS (Version 1.1.0.58). The problem occurs when I’m doing a global AP Search.
And then try to open Monitor or Config
NCS System Error Page
Error(s): You must correct the following error(s) before proceeding: Error:Unknown Exception Occurred. If the problem persists please send logs to the Tech Support. Error:Detail: No row with the given identifier exists: [com.cisco.rfm.model.servicedomain.BaseServiceDomain#579577094]
I have tried to move all my AP (25 st) with the names jkp-lju-w….to a different Wireless controller, but the same thing happens.
Any suggestion about the problem
Did you ever find a solution
Did you ever find a solution for this problem? I have have the same issue.
HiAfter upgrading my WISM2
After upgrading my WISM2 controllers to 7.4.121.0 and to 7.6.120 my problem was solved
587
