NCS Upgrade Version 1.1.0.58 - Problems ?
I need to Upgrade my NCS to version 1.1.0.58. Actually my NCS is in the version 1.0.1.4 and i have a lot of templates configured and 1500 Access Points applied.
I have 5 WLCs and will do too the upgrade in the WLCs to version 7.2.130.0.
Will I lose some configuration with these upgrades ? Because the version 1.1.0.58 has more features than version 1.0.1.4 in the NCS and the WLC was adjusted some bugs.
The configurations that i has in the NCS version 1.0.1.4 is H-REAP and in the version 1.1.0.58 will be the FlexConnect, theoretically is the same, but i don't know if the configuration is the same in the two versions.
Will i have some problem with these upgrades ?
Can i do a downgrade in the NCS from version 1.1.0.58 to 1.0.1.4 if i have problems ? I was looking for a document who show how can i do this, but i didn't find nothing about.
Thanks.
Everyone's tags (5)
1 REPLY
Hall of Fame Super Silver
Upgrade an downgrading is very much the same.  When you upgrade, you shouldn't loose anything, if you downgrade you might, depending if you have a feature in the newer version that isn't supported in the older version.  Take a look at the release notes for specifics on upgrading to the 1.1.058 version, they will have everything in there for you to perform the upgrade.
http://www.cisco.com/en/US/docs/wireless/ncs/1.1/release/notes/NCS_RN1.1.html#wp208350
-Scott
819
