Need DHCP related help with 1131AG
I have a 1131AG-K9 AP which gets an IP address from our central DHCP server. I also have it broadcasting a SSID but what I would like to happen is whenever a wireless client connects to the AP, I want them to receive a 192.16.x.x IP. Also, that 192.168.x.x network should not be able to access our production network. Effectively creating a small workgroup with 192.168 IP's and a WEP key.
Here is the config so far.
Thanks in advance.
__________________________________________
no service pad
service password-encryption
hostname NyoAP500
enable secret 5 !!!!!!!!!!!!!!
no aaa new-model
dot11 syslog
dot11 ssid NYO_Crestron
   authentication open
   guest-mode
username Cisco password 7 !!!!!!!!!!!!!!!!
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 !!!!!!!!!!!!!!!!!!!! transmit-key
encryption mode wep mandatory
ssid NYO_Crestron
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
ssid NYO_Crestron
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address dhcp client-id FastEthernet0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
line con 0
password 7 !!!!!!!!!!!!!!!!!!!!
login
line vty 0 4
login
end
NyoAP500#
1 ACCEPTED SOLUTION
Re: Need DHCP related help with 1131AG
Hi Sudip,
I think the BVI is on the different Vlan.. is that rite? i mean its not using vlan 192.. am i correct??
If so,then..
Please move the DHCP pool to the switch.. there are some issues if the BVI is on different subnet and if you are using some other subnet for clients for users and having internal DHCP pool for it..
Please check the below link..
http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37adm.html#wp1090319
Now the config should be..
>> Move the DHCP pool onto the switch..
>> Make the link between the AP and the Switch as a trunk port allowing vlan 192.
Now try connectivity..
Surendra
Hi Sudip,
You want the wireless clients connecting to SSID NYO_Crestron to grab IP in the range 192.168.x.x.Configure the vlan for 192.168.x.x as access vlan on the switchport connected to AP.
Hi Ritika,
I created a vlan and a DHCP pool. Now how do i attach the DHCP pool to the vlan?
Any client that connects to the AP times out and assigns itself a 169.254.x.x ip.
Thanks.
hostname NyoAP500
enable secret 5 !!!!!!!!!!!!!!!!
no aaa new-model
no ip dhcp use vrf connected
ip dhcp pool NyoWiFi
   network 192.168.1.0 255.255.255.0
   default-router 192.168.1.1
dot11 syslog
dot11 vlan-name WiFi vlan 192
   vlan 192
   authentication open
   guest-mode
bridge irb
no ip address
no ip route-cache
encryption key 1 size 128bit 7 !!!!!!!!!!!!!!!!!!!!!!!!!! transmit-key
ssid NYO_Crestron
station-role root
bridge-group 1
interface Dot11Radio0.192
encapsulation dot1Q 192
no ip route-cache
bridge-group 192
bridge-group 192 subscriber-loop-control
bridge-group 192 block-unknown-source
no bridge-group 192 source-learning
no bridge-group 192 unicast-flooding
bridge-group 192 spanning-disabled
no ip address
no ip route-cache
shutdown
ssid NYO_Crestron
dfs band 3 block
channel dfs
station-role root
bridge-group 1
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface FastEthernet0.192
no ip route-cache
bridge-group 192
interface BVI1
no ip route-cache
end
NyoAP500#
Hi Sudip,
Under the radio interface the Encryption in not napped to vlan 192.. so the clients are not getting the ip address..
please configure as below..
instead of.
Configure..
En
conf t
int dot11 0
no encryption key 1 size 128bit 7 !!!!!!!!!!!!!!!!!!!! transmit-key
no encryption moce wep mandatory
encryption vlan 192 key 1 128bit 7 !!!!!!!!!!!!!!!!!!!!! transmit-key
encryption vlan 192 mode wep mandatory
end
En
conf t
int dot11 1
end
wr
This will do it from CLI.. if you wanna use GUI.. then
AP>> Security >> Encryption manager >> Select the Vlan on top >> Select WEP Encryption >> Mandatory in the Drop down >> Key 1 >> Enter the Key >> Apply.
Now try connecting and let me know how this works out for you!!
Surendra
I did what you stated but stil no luck getting the client a 192.168.x.x IP.
Here is the latest config.
Thanks.
no service pad
hostname NyoAP500
enable secret 5 !!!!!!!!!!!!!!!!!!!!!!
no aaa new-model
dot11 syslog
   vlan 192
   authentication open
   guest-mode
username Cisco password 7 !!!!!!!!!!!!!!!!!!!!!!
bridge irb
no ip address
no ip route-cache
encryption vlan 192 key 1 size 128bit 7 070E1E805F752E470D231A346A65 transmit-key
ssid NYO_Crestron
station-role root
bridge-group 1
no ip route-cache
bridge-group 192
no ip address
no ip route-cache
shutdown
encryption vlan 192 key 1 size 128bit 7 19E12C01607439A64BD02E95042D transmit-key
ssid NYO_Crestron
dfs band 3 block
channel dfs
station-role root
bridge-group 1
interface Dot11Radio1.192
no ip route-cache
bridge-group 192
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
no ip route-cache
bridge-group 192
interface BVI1
no ip route-cache
ip http server
bridge 1 route ip
line con 0
login
line vty 0 4
login
end
Hi Sudip,
If so,then..
Surendra
Thanks guys. That worked out well just as I hoped it would work.
Thanks for posting on Cisco Support Community!!and its nice hear that the issue is resolved!!
have a great day
Surendra
581
