Need help to troubleshoot WDS configuration.
I'm trying to deploy WDS but I'm having a few problem connecting with a client to the ap. Access point is a Cisco Aironet 1040.
Current configuration : 3432 bytes
! Last configuration change at 08:30:28 UTC Fri Mar 1 2002
version 15.2
no service pad
service password-encryption
hostname ap
logging rate-limit console 9
enable secret 5 $1$OoEN$.2/pcffM5ZPX2lIcguYE3.
aaa new-model
aaa group server radius rad_eap88
server name 192.168.1.5
aaa group server radius Infrastructure
--More--
*Mar  1 08:30:28.669: %SYS-5-CONFIG_I: Configured from console  server name 192.168.1.5
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa group server radius clients
aaa authentication login eap_methods group rad_eap
aaa authentication login method_Infrastructure group Infrastructure
aaa authentication login mac_methods local
aaa authentication login method_clients group clients
aaa authentication login method_client group clients
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
no ip routing
no ip cef
no ip domain lookup
dot11 syslog
dot11 ssid testz
   authentication open eap method_client
   authentication network-eap method_client
   authentication key-management wpa
   guest-mode
dot11 guest
eap profile fast
method peap
dot1x credentials mange
username mange
password 7 1104180B1017
dot1x timeout supp-response 110
username Cisco password 7 14341B180F0B
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers tkip
ssid testz
antenna gain 0
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.1.5 255.255.255.0
no ip route-cache
ipv6 address dhcp
ipv6 address autoconfig
ipv6 enable
ip forward-protocol nd
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server local
  no authentication mac
  nas 192.168.1.5 key 7 1403171818
  nas 192.168.1.4 key 7 1403171818
  user wds1 nthash 7 1542282E52737F7C70636004445E412127047800010C5E5441410A7A0F0A070603
  user wds2 nthash 7 06562C031A175D415D47472D5B5D7D09027A126D704B57415A56057B000A015D54
  user mange nthash 7 0021305E5178535356021F165A405D424B295954790F000E63627B36574425220F
  user test nthash 7 025627795D5F5B79141E5C3F524E45292A560B73767063627B4454345B58030A0F
radius-server attribute 32 include-in-access-req format %h
radius-server vsa send accounting
radius server 192.168.1.5
address ipv4 192.168.1.5 auth-port 1812 acct-port 1813
key 7 051F031C35
bridge 1 route ip
wlccp ap username wds1 password 7 044F0E151B
wlccp authentication-server infrastructure method_Infrastructure
wlccp authentication-server client eap method_clients
  ssid testz
wlccp wds priority 254 interface BVI1
line con 0
line vty 0 4
transport input all
end
WDS info from the master:
ap#show wlccp wds
      MAC: 2c54.2d9e.21e9, IP-ADDR: 192.168.1.5    , IPV6-ADDR: ::                                     , Priority: 254
      Interface BVI1, State: Administratively StandAlone - ACTIVE
      AP Count: 2   , MN Count: 1
ap#show wlccp ap
       WDS = 2c54.2d9e.21e9, IP: 192.168.1.5     , IPV6: ::
state = wlccp_ap_st_registered
IN Authenticator = IP: 192.168.1.5      IPV6: ::
MN Authenticator = IP: 192.168.1.5      IPv6:
When I'm trying to connect via a client i'm receving:
*Mar  1 08:25:52.214: AAA/BIND(00000926): Bind i/f
*Mar  1 08:25:52.215: AAA/BIND(00000927): Bind i/f
*Mar  1 08:25:52.217: dot1x-registry:registry:dot1x_ether_macaddr called
*Mar  1 08:25:52.241: dot1x-ev(Do0): Role determination not required
*Mar  1 08:25:52.241: dot1x-packet(Do0): Queuing an EAPOL pkt on Authenticator Q
*Mar  1 08:25:52.243: dot1x-registry:registry:dot1x_ether_macaddr called
*Mar  1 08:25:54.976: dot1x-ev(Do0): Role determination not required
*Mar  1 08:25:54.976: dot1x-packet(Do0): Queuing an EAPOL pkt on Authenticator Q
*Mar  1 08:25:54.977: AAA/AUTHEN/PPP (00000927): Pick method list 'method_clients'
*Mar  1 08:25:54.978: RADIUS/ENCODE(00000927):Orig. component type = Dot11 Auth
*Mar  1 08:25:54.978: RADIUS(00000927): Config NAS IP: 192.168.1.5
*Mar  1 08:25:54.978: RADIUS(00000927): Config NAS IPv6: ::
*Mar  1 08:25:54.979: RADIUS(00000927): Sending a IPv4 Radius Packet
*Mar  1 08:25:54.979: RADIUS(00000927): Send Access-Request to 192.168.1.5:1812 id 1645/76,len 138
*Mar  1 08:25:54.979: RADIUS(00000927): Started 5 sec timeout
*Mar  1 08:25:54.981: RADIUS: Received from id 1645/76 192.168.1.5:1812, Access-Challenge, len 116
*Mar  1 08:25:54.981: RADIUS/DECODE: EAP-Message fragments, 20, total 20 bytes
*Mar  1 08:25:54.982: dot1x-registry:registry:dot1x_ether_macaddr called
*Mar  1 08:25:54.989: dot1x-ev(Do0): Role determination not required
*Mar  1 08:25:54.989: dot1x-packet(Do0): Queuing an EAPOL pkt on Authenticator Q
*Mar  1 08:25:54.991: AAA/AUTHEN/PPP (00000927): Pick method list 'method_clients'
*Mar  1 08:25:54.991: RADIUS/ENCODE(00000927):Orig. component type = Dot11 Auth
*Mar  1 08:25:54.991: RADIUS(00000927): Config NAS IP: 192.168.1.5
*Mar  1 08:25:54.992: RADIUS(00000927): Config NAS IPv6: ::
*Mar  1 08:25:54.992: RADIUS(00000927): Config NAS IP: 192.168.1.5
*Mar  1 08:25:54.992: RADIUS(00000927): Sending a IPv4 Radius Packet
*Mar  1 08:25:54.993: RADIUS(00000927): Send Access-Request to 192.168.1.5:1812 id 1645/77,len 185
*Mar  1 08:25:54.993: RADIUS(00000927): Started 5 sec timeout
*Mar  1 08:25:54.993: RADSRV: Unknown type 25 received for EAP NAK
*Mar  1 08:25:54.994: RADIUS: Received from id 1645/77 192.168.1.5:1812, Access-Reject, len 94
*Mar  1 08:25:54.994: RADIUS/DECODE: EAP-Message fragments, 4, total 4 bytes
*Mar  1 08:25:54.997: dot1x-registry:registry:dot1x_ether_macaddr called
*Mar  1 08:25:54.997: %DOT11-7-AUTH_FAILED: Station d0df.9afa.683a Authentication failed
*Mar  1 08:25:55.907: AAA/BIND(00000928): Bind i/f
*Mar  1 08:25:55.909: AAA/BIND(00000929): Bind i/f
*Mar  1 08:25:55.910: dot1x-registry:registry:dot1x_ether_macaddr called
*Mar  1 08:25:55.920: dot1x-ev(Do0): Role determination not required
*Mar  1 08:25:55.920: dot1x-packet(Do0): Queuing an EAPOL pkt on Authenticator Q
*Mar  1 08:25:55.922: dot1x-registry:registry:dot1x_ether_macaddr called
Any ideas what could be wrong? Also is it possible to just use WPA with a shared key and be able to fast-roam as I understand this is not possible.
Kind Regards
  • Security and Network Management
Everyone's tags (4)
Ok, so what cleint are you using and does it support LEAP or EAP-FAST?  If you are using the AP as the AAA for the clients it can only do LEAP or EAP-FAST.
Fom the debug, it looks like you are wanting to use PEAP for the client
"Unknown type 25 received for EAP NAK"
If you want to do PEAP for the clients you'll need ACS/IAS/NPS/etc
But your WDS setup looks good, as you have two AP registered in.
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Thanks for you answer. We're using the "built in client" in windows 7. I guess we would need some other(cisco?) client to get it working with LEAP or EAP-FAST?
Kind regards
Win7 should be able to support EAP-FAST
http://www.intel.com/support/wireless/wlan/sb/CS-032728.htm
HTH,
Steve
768
