Next step for a wifi guest network
All,
Now that an excellent engineer helped me get my wifi waps to work, wap1242.  I was thinking about creating a guest network that is not part of the internal LAN.
I have one Cisco switch, and one firewall.  Should I create a VLAN for the guest network and assign a different network to it?  The on the firewall route all traffic out to the Internet, via the same gateway or a different gateway?
I think the Cisco switch I have can do private vlans.  Would this feature help in this case?
As always, thanks all in advance for all the help.
Best regards.
refer http://www.cisco.com/en
refer http://www.cisco.com/en/US/docs/wireless/access_point/12.3_7_JA/configuration/guide/s37ssid.html
Thanks Soldh.  Not really
Thanks Soldh.  Not really what I was looking for.
Guess I was looking for more detail.
Such as:
1. Do I create a separate VLAN for the WAPs? The WAPs in use is only the internal LAN and GUESTS.
2. The WAPS are already on the internal LAN via IP.
3. How do I tell the WAPs that they have two SSIDs to signal?  Do I just add both SSIDs to the dotradio0/1?
4. Is there a way to limit the bandwidth for the GUEST SSID to say 5MB?  I have a 100MB Internet, and do not want the guests to connect to the WAPs and start using the bandwidth.
I am not a wifi guy, so I do not know how to make sense of this doc that I saw before to work for me.
hello dude, you can do either
hello dude,
you can do either this or that (private Vlan on switch , or separated out-band vlan for guest),
if you don't mind that guest users to utilize internal network , you can create separated vlan for guest users , and apply policy mapping (to limit bandwidth) in the firewall/router guest interface , refer to link below :
http://www.cisco.com/c/en/us/support/docs/wireless/5500-series-wireless-controllers/113435-wlan-user-rls-00.html
if you don't want guest users to communicate to each other use private vlan feature on switch ,
see link below , to see the needs of private vlans and how to configure it in switch:
http://www.cisco.com/c/en/us/td/docs/switches/lan/catalyst3560/software/release/12-2_52_se/configuration/guide/3560scg/swpvlan.html
choose what is suitable for your network needs
Bronze
Hi,Please refer the below
Please refer the below link
http://www.cisco.com/c/en/us/td/docs/wireless/access_point/1240/quick/guide/ap1240qs.html
61
