02-21-2002 11:57 AM - edited 07-04-2021 10:59 PM
So far I know that the aironet,airport, and xircom creditcard adapters are the only nics that support LEAP so far. I have also heard that Lucent cards support it as well. Can anyone confirm this? Anyone know of any other cards that can LEAP?
02-22-2002 03:54 PM
I got this from the TAC today:
"The only client cards I know of that support LEAP is our Cisco Aironet cards and Apple's Airport cards. "
Good luck
02-26-2002 07:38 AM
Thanks Alan.
01-30-2003 07:54 PM
Any NIC with the Intersil/PRISM chipset (Compaq, Fujitsu on-board) can use the Odyssey client from Funk Software and get seamless LEAP authentication. Open and Require EAP Authentication settings must be activated on the Access Point for this to work.
01-31-2003 07:53 AM
That would be EAP not LEAP
There is subtle differences between the 2.
LEAP is a Cisco protocol NOT standards based. EAP is standards based as defined under the 802.1x standard.
The previous post is correct only Cisco and the Airport cards support LEAP but many cards support EAP
