06-30-2007 02:42 AM - edited 07-03-2021 02:16 PM
What to choose normal or local or monitor?
I want to add these 3 features but see:
1)To enable Rogue Access Point Detection; AP should be in local mode or normal
2)To Configure MFP; AP should be in local mode or Monitor
3)To Configure CCX Radio Management; AP should be in Normal mode or Monitor
So, what to choose: (local, monitor or normal)?
Solved! Go to Solution.
07-11-2007 06:56 AM
Hi sbarasiscom,
I reckon you'd have to have a second AP in the same area to act as a sniffer or rogue detector or whatever you want to do with it.
Hope this helps
Scott
07-05-2007 11:58 AM
1. Monitor mode, 2) Monitor mode, 3) Loal Mode.
07-06-2007 10:25 PM
Thanks aghaznavi,
but if I want to apply 3 at the smae time , I have to apply only one.... So what to select
07-11-2007 06:56 AM
Hi sbarasiscom,
Hope this helps
Scott
07-11-2007 07:08 AM
Thanks Scott,
And that's what I am looking to do,
08-20-2007 07:48 AM
Belated Thanks for the points
Scott
