normal or local or monitor
What to choose normal or local or monitor?
I want to add these 3 features but see:
1)To enable Rogue Access Point Detection; AP should be in local mode or normal
2)To Configure MFP; AP should be in local mode or Monitor
3)To Configure CCX Radio Management; AP should be in Normal mode or Monitor
So, what to choose: (local, monitor or normal)?
1 ACCEPTED SOLUTION
Re: normal or local or monitor
Hi sbarasiscom,
I reckon you'd have to have a second AP in the same area to act as a sniffer or rogue detector or whatever you want to do with it.
Hope this helps
Scott
Silver
1. Monitor mode, 2) Monitor mode, 3) Loal Mode.
Thanks aghaznavi,
but if I want to apply 3 at the smae time , I have to apply only one.... So what to select
Hi sbarasiscom,
Hope this helps
Scott
Thanks Scott,
And that's what I am looking to do,
Belated Thanks for the points
Scott
182
