Number of APs on a Cisco Prime NCS map.
There is a limitation of 100 APs (objects) on a WCS map. As I have a very dense AP deployment this has required me to split my building maps into two. It makes it very hard to see the complete picture of my Wireless network due to the way I split it. As I'm getting ready to migrate to NCS, I'm considering changing how I split the maps.
The question I have is does Prime NCS have the same number of APs limitation as WCS?
If it doesn't then I don't have a problem and I can show the complete floor plan.
Tom
  • Security and Network Management
Everyone's tags (5)
1 REPLY
Hall of Fame Super Silver
Re: Number of APs on a Cisco Prime NCS map.
It's still limited to 100 access point on a given map.
Note : NCS allows a maximum of 100 access points per floor map.
http://www.cisco.com/en/US/docs/wireless/ncs/1.0/configuration/guide/maps.html#wp1283816
Thanks, Scott *****Help out other by using the rating system and marking answered questions as "Answered"*****
478
