Office extend SOHO AP can not connect to 5508
Dear all,
can anyone tell me the ACL Ports/Protocols which must be openend (in- and outbound) to enable a communication between a CISCO Office extend AP and a 5508 WCS.
Tx, Hajo
2 ACCEPTED SOLUTIONS
udp5246/5247 needs opening on the firewall for Officeextend AP to communicate to 5508 WLC ( thik you meant wlc and not wcs)
Re: Office extend SOHO AP can not connect to 5508
Hajo,
The OE access point uses two ports, as already mentioned. UDP 5246 and 5247. One port is the data plane and the other is the control plan.
__________________________________________________________________________________________ "Satisfaction does not come from knowing the solution, it comes from knowing why." - Rosalind Franklin ___________________________________________________________
tx, try it tomorrow....
Hajo,
436
