01-22-2014 07:53 PM - edited 07-05-2021 12:01 AM
Hello folks,
Is there any way to authenticate AP600 to WLC when it joins the WLC over CAPWAP tunnel ?
I didn't find any good methods to controll this process. Technically, anyone who knows the public IP of WLC can easily join their AP and get connected to the internal office environment.
And secondly, will 801.x work against the AD if I set Layer 2 security to 801.x ?
Solved! Go to Solution.
01-22-2014 08:17 PM
Take a look at the link I posted as it shows you where you have to enter the mac address and whay you need to check.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
01-22-2014 08:09 PM
Best practice is to use mac fliters. If you have OEAP's and regular AP's on the same WLC, then you will need to add all the mac address to each WLC's. I have not tried to see if 802.1x works or not.
Scott
01-22-2014 08:11 PM
I should say... per this guide:)
http://www.cisco.com/en/US/products/ps11579/products_tech_note09186a0080b7f10e.shtml#config-steps
Scott
01-22-2014 08:14 PM
Thank you, Scott
I thought that MAC filtering is already history and the least secure method as MAC address can be easily spoofed. How would I do it?
WLC: Security -> AAA -> MAC Filtering -> MAC Filters ?
Once it is enabled then all wireless clients will be filtered as well ?
01-22-2014 08:17 PM
Scott
01-22-2014 08:21 PM
I remember reading this guide but didn't find how exactly it is done
The guide is missing what MAC address I enter in that filter and what are those certificate types, i.e. MIC, SSC, LSC
01-22-2014 08:22 PM
And another question that may of course sound stupid but still valid.
What about split tunneling ? Let's say I don't want to send all internet bound traffic into the CAPWAP tunnel
01-22-2014 08:24 PM
Take a look at this support doc... I haven't had to deploy this yet but I have tested it when it initially came out, not with newer code though:
https://supportforums.cisco.com/docs/DOC-27758
Scott
01-22-2014 08:22 PM
The OEAP 600 ethernet mac address and all your AP mac address. Then enable or check: Authorize MIC APs against auth-list or AAA
Scott
01-22-2014 08:25 PM
The only MAC address I see on AP600 is the one on the back on the sticker. What's "all your AP mac address" ?
Didn't understand
01-22-2014 08:27 PM
Once you enable "Authorize MIC APs against auth-list or AAA", then all AP's that join that WLC will need to have their mac address added or else, if they bounce, get rebooted or whatever, they will fail to join. You just need to add the mac address on the sticker.
Scott
01-22-2014 08:32 PM
Ok, thanks again, Scott.
Quite a lot of things to test and validate. Will update if I had progress or stumbled upon something new
01-22-2014 08:35 PM
Sounds good... hopefully that info helped.
Scott
01-25-2014 09:20 AM
Hello Scott,
I ran into a problem while testing 801.x user authentication. The WLAN on the controller is set for 801.x under layer 2 security but when the user tries to connect to the SSID he is challenged with PSK. Weird, I remember it was working before I upgraded the controller from 7.3 code to the latest 7.6 (I did it to test split tunneling)
I don't believe it is related to the upgrade but who knows, just wanted to ask for a fresh opinion.
And by the way MAC based authentication for AP works perfect !
01-25-2014 10:03 AM
I would verify the WLAN setting and the AP Group if you have any created. I would also check what the uses are actually seeing.
