You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Operational Status down on AIR-LAP1041N-E-K9 APs after WLC2504 upgrade from 7-5-102 to 7.6.130
Before upgrade, all was fine.
Couple of months ago I tried upgrading this WLC from 7-5-102 to 7.6.120, and had the same problem,
At another site with similar WLC/APs upgrade to 7.6.130 works fine, so I just re-tried, upgrading to 7.6.130, but with the same error result.
Reading 7.6.130 release notes, the 1041 should be supported, in WLC config
In WLC config,  country NL is enabled.
Any hints/tips welcome...
  • Security and Network Management
Everyone's tags (1)
Hall of Fame Super Gold
Post the following command
Post the following command outputs:
1.  WLC:  sh sysinfo;
2.  AP:  sh version
Leo, See below for slightly
Leo,
See below for slightly anonymized output of requested commands:
(Cisco Controller) >show sysinfo
Manufacturer's Name.............................. Cisco Systems Inc.
Product Name..................................... Cisco Controller
Product Version.................................. 7.6.130.0
Bootloader Version............................... 1.0.20
Field Recovery Image Version..................... 7.6.101.1
Firmware Version................................. PIC 16.0
Build Type....................................... DATA + WPS
System Name...................................... xxxxWLC01
System Location.................................. xxxx
System Contact................................... xxxx
System ObjectID.................................. 1.3.6.1.4.1.9.1.1279
IP Address....................................... 10.xxx.xxx.3
Last Reset....................................... Software reset
System Up Time................................... 0 days 0 hrs 13 mins 27 secs
System Timezone Location.........................
System Stats Realtime Interval................... 5
System Stats Normal Interval..................... 180
--More-- or (q)uit
Configured Country............................... NL  - Netherlands
Operating Environment............................ Commercial (0 to 40 C)
Internal Temp Alarm Limits....................... 0 to 65 C
Internal Temperature............................. +31 C
External Temperature............................. +34 C
Fan Status....................................... 4600 rpm
State of 802.11b Network......................... Enabled
State of 802.11a Network......................... Disabled
Number of WLANs.................................. 6
Number of Active Clients......................... 0
Burned-in MAC Address............................ F4:7F:35:xx:xx:xx
Maximum number of APs supported.................. 5
xxxxAP02#sh version
Cisco IOS Software, C1040 Software (C1140-K9W8-M), Version 15.2(4)JB6, RELEASE S
OFTWARE (fc1)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Fri 22-Aug-14 12:44 by prod_rel_team
ROM: Bootstrap program is C1040 boot loader
BOOTLDR: C1040 Boot Loader (C1140-BOOT-M) Version 12.4(23c)JA3, RELEASE SOFTWARE
 (fc1)
xxxxAP02 uptime is 7 minutes
System returned to ROM by reload
System image file is "flash:/c1140-k9w8-mx.152-4.JB6/c1140-k9w8-mx.152-4.JB6"
Last reload reason:
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1041N-E-K9 (PowerPC405ex) processor (revision A0) with 90102K/40960
K bytes of memory.
Processor board ID FCZ1626W3KN
PowerPC405ex CPU at 333MHz, revision number 0x147E
Last reset from reload
LWAPP image version 7.6.130.0
1 Gigabit Ethernet interface
1 802.11 Radio
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: A4:93:4C:46:A2:F0
Part Number                          : 73-14034-05
PCA Assembly Number                  : 800-34273-06
PCA Revision Number                  : A0
PCB Serial Number                    : FOC16203A38
Top Assembly Part Number             : 800-34284-04
Top Assembly Serial Number           : FCZ1626W3KN
Top Revision Number                  : A0
Product/Model Number                 : AIR-LAP1041N-E-K9
Configuration register is 0xF
Output above shows 802.11a is disabled.
AIR-LAP1041N-E-K9
Your AP also shows only one radio, 802.11b radio.
On the AP, post the output to the command "sh ip interface brief".
Leo,On 1041 AP there's only a
Leo,
On 1041 AP there's only a 802.11bgn 2.4G radio, so there's no 802.11a 5G radio to enable
Interface                    IP-Address        OK?  Method Status    Protocol
BVI1                         10.xxx.xxx.102   YES  DHCP     up            up
Dot11Radio0             unassigned        NO   unset     reset        down
GigabitEthernet0       unassigned        NO   unset      up             up
GigabitEthernet0.1    unassigned       YES  unset      up             up
Your radio is "reset".
Console into your AP and reboot the AP.  I want to see the entire bootup process.
You may also want to upgrade the firmware of your WLC to 7.6.130.X for stability purposes.
Leo,I'm an external sysadmin,
Leo,
I'm an external sysadmin, so no console access.
Is logging via network an alternative to gather info?
What do you mean with firmware upgrade?
Before topic start, I already used these files to upgrade:
AIR-CT2500-K9-1-9-0-0-FUS.aes
AIR-CT2500-K9-7-6-130-0.aes
Oops.  Sorry.  Didn't read
Oops.  Sorry.  Didn't read the bit about the firmware your WLC is running on.
There are some information only found when you console into an AP and the AP is reloaded.  You won't find this anywhere else, unfortunately.
I've enabled telnet on AP,
I've enabled telnet on AP,  is attached log granular enough?
It shows output of "show log" command for both WLC versions.
Doesn't really show much.
Doesn't really show much. The output to the console when you boot up an AP can show whether or not the radio drivers were loaded correctly or not. Or it could be a firmware bug.
236
