08-17-2010 11:07 AM - edited 07-03-2021 07:05 PM
I'm working with a customer that has several WLC in place and working already. They now want to get a WCS server with location services in place. Does the licensing strictly depend on the number of APs in use, not the number or type of WLCs?
For a linux server, the part number I want is AIR-WCS-LL-1.0-K9, isn't it? Does that part number include any AP licenses? And the additional APs are licensed in multiples of 50, 100, and 500, correct?
Thanks!
08-17-2010 11:37 AM
Here is the ordering guide:
http://www.cisco.com/en/US/prod/collateral/wireless/ps5755/ps6301/ps6305/product_data_sheet0900aecd804b4646.html
You have different feature sets and the part you want is WCS-STANDARD-K9
or WCS-ENT-PLUS-K9. You will download the WCS flavor you want from the
website (windows / linux)
Licensing is by number of access points :
Example for Standard license:
If you are a NEW Cisco WCS customer who wants support for 50, 100, or
500 access points in a single server deployment, order WCS-STANDARD-K9
and select one of the Cisco Base options below:
WCS-APBASE-50: License supports up to 50 access points.
WCS-APBASE-100: License supports up to 100 access points.
WCS-APBASE-500: License supports up to 500 access points.
Note: If your access point deployment does not exactly match 50, 100 or
500, you need to order multiple licenses. For example, to support an
access point deployment of 250 you would order (2) WCS-APBASE-100
licenses + (1) WCS-APBASE-50 license. This ordering process applies to
both new and upgrade orders.
• If you are an EXISTING Cisco WCS customer who wants to increase access
points support within a single server deployment, order WCS-STANDARD-K9
08-17-2010 11:42 AM
OK, thank you... I didn't realize that version supported location services.
12-08-2010 09:05 PM
I’m not sure to understand, can you confirm this:
If I order the licence WCS-APBASE-100, the WCS standard-k9 is included in this price with no additional cost?
Christian
08-17-2010 11:52 AM
I missed the location question part, you are correct for location
feature, then the AP license needs to be either plus or enterprise plus:
WCS-PLUS-50: License supports up to 50 access points.
WCS-PLUS-100: License supports up to 100 access points.
WCS-PLUS-500: License supports up to 500 access points.
WCS-ENT-PLUS-1000: License supports up to 1000 access points.
WCS-ENT-PLUS-2500: License supports up to 2500 access points.
WCS-ENT-PLUS-10000: License supports up to 10000 access points.
WCS-ENT-PLUS-50000: License supports up to 50000 access points.
08-17-2010 11:58 AM
Oh, I see... is the AIR-WCS-LL-1.0-K9 an older product?
08-17-2010 12:07 PM
Correct
12-11-2010 08:25 PM
Just wanted to add for your benifit.
If you have future cusotmers that have "base" WCS and want location you can purchase an "upgrade" license. Just and FYI
01-31-2011 05:01 AM
We are planning to get 2x Enterprise WCS servers to be running on High Availability for 600 APs.
Understand that the Enterprise WCS License allows us to “load share” the license between multiple servers.
Should the top-level part number (WCS-ENT-PLUS-K9) be chosen as qty 1 or qty 2?
WCS-ENT-PLUS-K9 Family SKU for WCS Enterprise PLUS License Products 2 USD -
WCS-ENT-PLUS-1000 Cisco WCS Enterprise PLUS License for 1000 APs,Windows/Linux 2 USD 80,245.00
CON-SAU-WENTP1K SW APP SUPP + UPGR Cisco WCS Enterprise 2 USD 16,049.00
CON-SAU-WENTK9 SW APP SUPP + UPGR Family SKU for WCS E 2 USD -
I refer to the URL:
If you are a NEW Cisco WCS customer with an enterprise deployment and want single device Location tracking, High Availability, and support for 1000, 2500, 10000, or 50000 access points, order WCS-ENT-PLUS-K9 and one of the Cisco WCS PLUS options below:
02-09-2011 11:46 PM
Yes. It depends on the number of APs.
