05-16-2003 07:18 AM - edited 07-04-2021 08:42 AM
We have the situation, that we have much Packet CRC Errors on the radio site (2,6MIO!!) since yesterday. What could cause this errors? The most clients on the APs are WGB350.
and which parameters should we check that the AP is in "good" condition. we have also the wlse.
thx reagards Bernhard
Solved! Go to Solution.
05-18-2003 04:41 PM
Packet CRC error are most commonly caused by RF interference
05-18-2003 04:41 PM
05-21-2003 01:12 AM
Do you have any docs or infos with "mib" oder something i should check is the ap is a good condition. i have the problem that sometimes some aps "die" -> i have to reboot them, the problem is that i have to drive to them, they are not in my office.
hope you can help me
bernhard
