Password Recovery on WLC not working
I have a 4404 running firmware 7.0 and something happened (don't think it was a hack), but all of a sudden I can't login to the box via web or ssh or even telnet.
In trying the recovery procedure, I get a lot of messages scrolling through and cannot do the Restore-Password command on the CLI.
I'm attaching the whole capture, but here's a truncated capture from the procedure:
*fp_main_task: Nov 21 10:39:46.501: sshpmGetCID: comparing to row 0, CA cert >bsnOldDefaultCaCert<
*fp_main_task: Nov 21 10:39:46.501: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*fp_main_task: Nov 21 10:39:46.501: sshpmGetCID: comparing to row 2, CA cert >bsnDefaultCaCert<
*fp_main_task: Nov 21 10:39:46.501: sshpmGetCID: called to evaluate <cscoDefaultIdCert>
ok
Starting AireWave Director: ok
Starting Network Time Services: ok
Starting Cisco Discovery Protocol: ok
Starting Broadcast Services: ok
Starting Logging Services: ok
Starting DHCP Server: ok
Starting IDS Signature Manager: ok
Starting RFID Tag Tracking: ok
Starting Power Supply and Fan Status Monitoring Service: ok
Starting Mesh Services:  ok
Starting TSM: ok
Starting CIDS Services: ok
Starting Ethernet-over-IP: ok
Starting DTLS server:  enabled in CAPWAP
Starting CleanAir: ok
Starting WIPS: ok
Starting SSHPM LSC PROV LIST: ok
Starting RRC Services: ok
Starting FMC HS: ok
Starting Management Services:
   Web Server: ok
   CLI: ok
   Secure Web: ok
(Cisco Controller)
Enter User Name (or 'Recover-Config' this one-time only to reset configuration to factory defaults)
User:  *fp_main_task: Nov 21 10:39:46.501: sshpmGetCID: comparing to row 1, CA cert >bsnDefaultRootCaCert<
*fp_main_task: Nov 21 10:39:46.501: sshpmGetCID: comparing to row 3, CA cert >bsnDefaultBuildCert<
*fp_main_task: Nov 21 10:39:46.501: sshpmGetCID: comparing to row 4, CA cert >cscoDefaultNewRootCaCert<
So as you can see, my prompt to enter the command is taken up by this fp_main message and it uses up the first and only time I can enter this in.
I'm trying everything I can to not have to go back to factory defaults. That would be a nightmare.
Is there a way to stop these messages? Thanks any and all for your help.
Hall of Fame Super Silver
Re: Password Recovery on WLC not working
During the boot up, you should see something that tell you to hit ESC to enter the boot menu. From there you can reset the WLC to factory default.
Scott F. Fella
Sr. Network Engineer
CDW Corporation
CDW Plaza - 120 S. Riverside
Ninth Floor
Chicago, IL 60606
Cell: 630-935-7333
e-Mail: scott.fella@cdw.com
Reply-To: "cisco-support@sgaur.hosted.jivesoftware.com" >
Date: Mon, 28 Nov 2011 08:04:42 -0700
To: Scott Fella >
Subject: - Password Recovery on WLC not working
Home<>
created by rmazzagate<> in Security and Network Management - View the full discussion<>
-Scott
Thanks, but I'm not interested in factory defaults. That's my last option. I'm trying to just reset the username/password.
I see you have already done a reboot. Can you disconnect the WLC from the network and see if you are still getting the messages on your console
NikhiL
Good point. I'll give that a try
I didn't see that part:)  Sorry about that.
-Scott
No problem, Scott
HI Scott ,
Please find the video for the password recovery
https://supportforums.cisco.com/docs/DOC-8038
Angus
Yeah.. I have seen that, I just thought you were having an issue resetting the WLC to factory default using the recover-config.
Scott F. Fella
CDW Corporation
Ninth Floor
Chicago, IL 60606
Cell: 630-935-7333
Date: Mon, 28 Nov 2011 09:12:21 -0700
To: Scott Fella >
Subject: - Re: Password Recovery on WLC not working
Home<>
created by Angus Bishop<> in Security and Network Management - View the full discussion<>
-Scott
Silver
All of that console output looks like certificate stuff for AP joins.
Does that output stop after your reboot (say 5-10 minutes later?) and all the APs are joined?
What about if you just type Restore-Password  when the login prompt first appears,  instead of hitting enter and getting the login prompt again? Are you sure the console log message is actually becoming text for the Login Prompt?
OR, what if you hit the backspace a thousand times (exaggeration) and then hit Restore-Password    if you think that console output line is filling in the username field...?
By the way..... if you have a WCS   or any other snmp device, you could probably jsut send snmp to create a new user....
Yeah, I've tried just putting in the Restore-Password after the login prompt finally comes up and it didn't work. That's what makes me think that, like you said, the message may be acting like text for the login. I'm going to try what one poster said and unplug it from the network and then try the procedure.
Silver
Yep, that makes alot of sense.  If those messages are because of AP joins, then it stands to reason that those messages will go away when disconnected and your prompt might return.
But more to my question, do you not have a WCS in play here?  Because it would be a lot less intrusive to just send a new user account with snmp....?
No, I don't have a WCS in place. Forgot to address that.
Well, unplugging from the network didn't work. Those messages still scroll and still can't reset the password. Not sure what next step should be. Really don't want to go back to factory defaults.
You can try few more options
When the device boots up break down the boot menu and try to boot with backup image,if it is something different
You have mentioned that you dont have a WCS, but in case you have a SNMP community and you know the details, you can try with the Cisco MIBS, to reset your password. You will have to download the Cisco MIBS corresponding to the software version you are running, identify the MIB corresponding to password and then try to change by MIB walk
NikhiL
Actually, I finally got the reset working. BUT, it's not working! I created a new username and password but I still can't log in with it. What in the world could be preventing this? It's like it's disabled or something. Web interface, ssh, telnet, it doesn't work. Any ideas? Thanks for all your time!
Silver
Is it possible that you managed to set login for tacacs/radius only?  That would explain why local username/passwords don't work for you.....
Have you tried to login with any tacacs/radius accounts?
Great point, and I was wondering if I somehow accidentally chose that option when I was in there last. The only radius config I'm using is by computer authentication. For fun, I tried my Active Directory credentials but it didn't work. Any other ideas or thoughts are most welcomed. Thanks.
Silver
So.... do you know if you removed the default SNMP communities?
As suggest by others, you could get an snmp tool to try to fix this.
You might even could get a demo WCS?
WLCs have a default read/write community, so if you haven't changed it, you're open for that.....
No, the community strings are still in there. In fact, it's still generating logs to my syslog server. So do you think that the WCS could help even when what appears to be the local authentication could be turned off? Thanks for all your time.
Ok, I'm getting close. I can console in with the network cables unplugged. What I think is happening is the Local User is either low priority or disabled and it may be trying to find a TACACS server when plugged into the network.
Can someone tell me the CLI commands I need to make the Local User top priority when logging into the box? Note: not to be confused with Local EAP.
Thank you.
Try this:
config aaa auth mgmt local radius
-Scott
Booyah!! Everything's fine now. So in summary, somehow the authentication priority got changed to a TACACS+ first then local. So I unplugged the WLC from the network, consoled in and put in my credentials and got in. From there, I did "config aaa auth mgmt local tacacs". That set local back to priority.
Thanks everyone for all you input and help!
Thanks everyone for participating and helping out Roy .
Roy could you please mark this thread as Answered?
Vinay Sharma
Community Manager - Wireless
Thanks & Regards
I was going to yesterday, Vinay, but I can't find on the page where to do that.
2074
