PEAP Cert on MS Stand Alone CA
I am trying to generate a certificate for PEAP authentications for my Aironet 1250.  The CA is a MS Stand alone CA.  I get the following error in my event log on the IAS server.
Could not retrieve the Remote Access Server's certificate du to the following error: The credentials supplied to the package were not recognized.
Anyone have instructions on how to generate a certificate on a MS Stand alone CA?
Thank you,
Re: PEAP Cert on MS Stand Alone CA
I figured out the issue.  When creating the certificate on MS CA. You must submit an advanced request.  Use "Server Authentication" type and MUST check Store Certificate in the local computer store.  I was leaving that unchecked and copying the the cert from the user store to the computer store.
Thanks for reporting back on how you solved the issue. 5'd.
774
