PEAP/IAS - 350 Card driver problems
When I update the drivers for the Cisco 350 wireless card IAS fails user authentication.
We are using:
Win2003(IAS) - PEAP MSCHAPv2
Cisco AP 1200 - 12.2(13)JA1
WinXPSP1
Driver version 7.50.01 works OK
Driver version 8.5.24.0 FAILS
We have tried updating firmware and have installed MS patches on XP: KB826942, KB822725
Any ideas?
1 REPLY
Re: PEAP/IAS - 350 Card driver problems
I found the problem:
Disable "Enable Fast Reconnect" - problem with XPSP1
Microsoft will fix in SP2
In IAS configuration select Vendor as Cisco not "RADIUS Standard".
137
