PEAP with Verisign
Has anybody implementet PEAP with an offical verisign CA not with an windows CA server? is there anything different from configuring the acs? bc in the peap guide with acs and ca server you need to configure the ROOT ca in the acs from the ca server (as a file).
do i need a versign root ca? bc the acs has all the root cas.
can anybody give me a guide or tell me how i have to configure the acs?
regards Bernhard
1 ACCEPTED SOLUTION
Re: PEAP with Verisign
Bernhard,
ACS has a list of Root CA (including Verisign) in the "Certificate Trust List".
You don't need to install a Verisign root CA cert.
Ami
Bernhard,
Ami
Thanks for the anwer, does also a thawte (http://www.thawte.com/) CA work? i found thawte root ca in the acs 3.2 but what kind must i buy? webserver? verisign offers a RADIUS WLAN CA =) is this compatible with ACS 3.2?
bernhard
157
