PI 1.4 Performance
thomaslthorne
I am currently running PI 1.4.1 with poor performance, especially when viewing maps.  I tend to get a lot o JRE crashes when maps are viewed.  I'm suspecting that I have an IOPS issue, but the command that I have found (ncs run test iops) is not available in 1.4.1.  Does anyone know how to test IOPS performance in 1.4.1?
Scott Fella
Interesting.... its available in PI 2.0....
What happens if you run: ncs run list
Prime01/admin# ncs run list
commands :
  list - prints this list
  test iops - tests the disk write performance
  reset db - reset database to default factory settings
Scott
*****Help out other by using the rating system and marking answered questions as "Answered"*****
-Scott
Everything I've read shows that it's supposed to be there, but run isn't even an option.
ncs1/admin# ncs ?
  cleanup   Disk cleanup
  db        Control database operations
  ha        Control high availability operations
  key       Control keyadmin operations
  password  Change passwords
  service   Service Commands
  start     Start NCS
  status    Print Status of NCS
  stop      Stop NCS
hahaha... well it seems like they forgot something:)  Do you know if your disks do meet the requirements in the install guide?  Was this a clean install or upgrade to PI 1.4?  if it was an upgrade, you might want to bring up a new VM PI 1.4 and patch it to update 1 and rehost the license, add the WLC's and import the floor plans.  Upgrades don't work too well.
Scott
-Scott
