PI 2.0 heatmap prediction
I have created a map and placed my 3602E APs with AIR-ANT2566P4W-R= antennas. The heatmap prediction is displayed, but I do not believe it is anywhere close to what the actual coverage is. I believe my issue is when you setup an antenna it ask you for azimuth and elevation degrees. These antennas are placed in a 30ft ceiling facing straight down. i have the azimuth set to 90 degrees and the elevation to 90 degrees down. The heatmaps seem much smaller than what the actual coverage is. Did i set the azimuth incorrect? If i'm right it is the only setting that really applies to the way I have my antennas placed.
203
