Community Member
PI21AG bad connection and no 'a' radios?
I installed a new card into a computer this morning and it was connecting fine. When I go back in to look at it and fire up the site survey utility, it doesn't see any of the 802.11a interfaces on my access points. Is there something potentially wrong with this card, I made sure that the options were enabled in the ADU? I am trying to ping the card from my switch and the success rate is about 80%. I can ping 3 other clients on this AP/ssid at 99-100%. I had my laptop right next it (using a CB21AG) and the 11a interfaces were present. thanks, dave
Community Member
Re: PI21AG bad connection and no 'a' radios?
some more information - I just spoke with the user of this card, and due to the terrible connection I had them switch over to a wpa-psk (originally connected to an EAP-TLS) ssid. The connection on this one is stable. Most of the pings are coming back at <= 1ms, with about every 7th coming in at 35ms or 40ms. This card has the latest drivers as well. If I can dig up another one of these cards I will try swapping and see what happens. dave
