You may experience some slow load times, errors, and slight inconsistencies. We ask for your patience as we finalize the launch. Thank you.
Pix: LAN Failover - Cross-over Cable Won't Fly
At the informational link below - we are informed that when using LAN interfaces for failover link you must go through a switch and not use a cross-over cable between the two pixes in the pair. It does not however explain why this is the case. Does anyone know why a switch must be involved in the picture to make this work?
http://www.cisco.com/univercd/cc/td/doc/product/iaabu/pix/pix_sw/v_63/config/failover.htm
  • Security and Network Management
1 REPLY
Silver
Re: Pix: LAN Failover - Cross-over Cable Won't Fly
Cable based failover is used in statefull failover,The importance of switch is that the primary and secodary pixes should be active in the network.
99
