Prablem with baud rate on AIR-AP1252AG
Hi ,
I changed Baud rate on rommon to 115200 for fastest  sending IOS . But now I cant connect to device any way !!!!
I want to back baud rate to 9600 but I cant do that . The hardware reset did not help me.
Please show me way to connect again to my device.
Thank you
2 ACCEPTED SOLUTIONS
Hi Pedram,
It could be because of your setting on Putty or Hyper somethings like Flow Control or ...  also sometimes the Software or the PC/Laptop which is using have a BUG to transfer the Data between two devices due to the IOS then I suggest you to check it also with other PC/Laptop.
Hesam
Sorry , i mean to say to do console/telnet and access this page and then you can change the baud-rate
Hall of Fame Super Silver
The baud rate should be changed on your laptop or pc.  A factory reset would default the AP which would put it back to 9600.  If you were in ROMMON mode and you set the baud rate there, you should be able to get back into ROMMON and change it.  Hold the mode button for 10 seconds to get to ROMMON.
https://supportforums.cisco.com/docs/DOC-14636
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Re: Prablem with baud rate on AIR-AP1252AG
Hi ,
I changed Baud rate on my laptop and connected to device ,  But in Hyper terminal or putty  When I'm typing commands a unknown characters displayed.
ap: ÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃà þààØþààØàæþü ÙÀþ þð üÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃ
ÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃ
*** line too large ***
Unknown cmd: ÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃà þààØþààØàæþü ÙÀþ þð üÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃ
ÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃÃ
Thank you
Hi Pedram,
Hesam
You can try to console/telnet through the management port to change the baud settings back to 9600.
Please do not forget to mark as answered if your query is resolved.
Hall of Fame Super Gold
APs do NOT have "management port".
Thanks to all
I changed flow control and other things on hyper terminal But the The problem still exists.
Strange problem!!!!!
Hi Pedram,
The last idea which I can suggest you it's because of the Firmware. You can Upgrade OR reinstall current version again. Actually it should be a miss match configuration on endpoint of remote term between two devices which are connected together.
Hesam
Oh no.  You're not using them USB-to-console are you?
I dont have any access to device to upgrade or reinstall version .
I tried both with USB-to-console on laptop and directly to COM port on my desktop PC .
Thank you
Pedram
Hi Pedram
You are right. It forgot it which was your main problem connecting to your device. Sorry for massage that was like a JOK.
Hesam
437
