Prablem with baud rate on AIR-LAP1310G
I changed Baud rate on rommon to 115200 to send IOS, but now I can't connect to device with console.
I've tried every possible baud rate with Xshell, like 110, 300, 600, 1200, 2400, 4800, 9600, 14400, 19200, 38400, 57600, 115200, 230400, 460800, 921600
I still can't connect to AIR-LAP1310G.
I want to set the baud rate back to the default value 9600, but I can't find Mode or Reset button on the AIR-LAP1310G. Using the wireless controller to send IOS to the AP and transfer it to thin AP didn't help neither.
Or it can just be solved by RMA?
Please show me way to connect again to my device.
Thank you.
You can ammend the band rate
You can ammend the band rate in rommon mode again
Thanks.But the problem is I
Thanks.
But the problem is I changed the baud rate to 115200 in rommon. Then I can't connect console to it anymore, in rommon or regular startup. I've tried every possible baud rate of my terminal app to connect to the AP. All failed.
I can't find MODE or RESET button on the AP, neither.
So....can't figure out how to solve this strange problem.
You probably need a processer
You probably need a processer & cable to access the upper bandwidth for 115200.
Refer to
http://www.tldp.org/HOWTO/Remote-Serial-Console-HOWTO/preparation-setspeed.html
Have you figured this one out
Have you figured this one out? I'm having the same problem..
112
