Prime infrastructure 1.3 / 2.0 - LMS 4.2 and NCS PI coexist on one physical appliance?
Derrick Robba
I would like to purchase the physical appliance the serves both LMS/NCS. Is this possible on the NCS appliance running 1.3 or is this only available on a 2.0 appliance. If so any documentation supporting this would be appreciated..
7 Replies 7
Leo Laohoo
CPI 2.X is available in VM & appliance.
According to our SE, Cisco has put PI 2.X (and any future PI releases) back on the table for appliance.
Sent from Cisco Technical Support Nintendo App
Do you know if LMS and NCS can coexsit on the same box on 1.3?
No it can't.
-Scott
Great, So PI 2.0 will not support this as well? Sorry to keep harping I just need some clarity, I have been reading conflicting posts on this.. I was under the impression that centralized management was the whole point behind PI.. Apparently not..
Do you mean on the same ESX based box as a virtual appliance? I guess that would be possible, if you meet the hardware requirements.
You can't run two systems on an appliance. An appliance allows only one OS to run at a given time.  PI and LMS need to be ran on a separate VM'swhich can be on the same VM host, but are individual virtual machines.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Thank you..
