Prime Infrastructure 1.3 + WLC 2504 - Enable LAG?
Hi everybody,
I'm facing a little issue using Prime Infrastructure 1.3 configuration templates to manage a couple of 2504 WLCs.
I'm using a Configuration -> General template to enable LAG on a couple of controller and when I try to apply it I get the error: "LAG mode cannot be enabled for 2500 series of controllers."
Obviously I can enable LAG locally on controllers, but then each time I try to apply the configuration template from Prime Infrastructure LAG gets disabled again.
Is this a known issues? Does anybody known how it can be worked around?
L
1 ACCEPTED SOLUTION
There is a defect in PI 1.4 that you can't enable LAG for the 2504.  It's possible that 1.3 also affected
https://tools.cisco.com/bugsearch/bug/CSCui37076
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
VIP Purple
HI Luigi,
Which version software you are running on 2504 WLC.
2504 supports LAG in v7.4. or higher versions.
Paste the output of command sh sysinfo from 2504 wlc.
Dont forget to rate helpful posts
I'm using 7.4.115.0 and LAG is available in local interface.
HTH,
Steve
Thanks for pointing this bug to me. Description correctly applies to my 1.3 installation (updated to Patchbundle 4). I suspect the bug is present in 1.3 too, since LAG was added in WLC 7.4 software.
Hall of Fame Super Silver
Your version must be a Cisco TAC release and that can be another cause... possibly look into v7.4.121.0
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
7.4.115.0 is an hotfix supporting iOS 7.0 with ISE. I will upgrade to 7.4.121.0 at next reboot, but the bug reported by Stephen seems the best match to my issue.
It is.... just need to be aware of TAC versions not being compatible all the time with other hardware.  I would make sure v7.4.121.0 does fix your issue with ISE before upgrading.
Scott
-Scott
I would never push out templates like that from PI.  Depending on how the WLC is configured, can cause you issues.  Like Sandeep mentioned, you need v7.4 to enable LAG, but you must be on that version since you mentioned you can configure LAG locally on each WLC.  I would stick to that.... configure each WLC manually.
Scott
-Scott
283
