Prime Infrastructure 2.1 - Deploy Wireless Template
bm_5789
As a test, I set up a simple template to push to one access point.  I am doing this in PI2.1.  Every time I try to deploy the template, it fails.  I cant figure out why.  So I am attaching a screenshot of the error and hope that some one else knows how to correct this issue.  TIA!
vivsreev
You have not set the SNMP write community string. if that's set then you will not see this error.
Saurav Lodh
Level 7
Level 7
http://www.cisco.com/c/en/us/td/docs/net_mgmt/prime/infrastructure/2-1/user/guide/pi_ug/create_temps.html
