Prime Infrastructure with autonomous AP AIR-CAP vs AIR-SAP
I have two AP, both running on autonomous IOS image 15.2(2)JB2. One came with a autonomous Product ID and the other one was migrated from a lightweigt image.
PID     AIR-SAP2602I-E-K9
PID     AIR-CAP3602I-E-K9
Now when i want to add both to Prime Infrastructure 1.4, only the SAP is discovered correctly. The CAP is mistakenly discovered as unified AP. I think its because auf the PID.
  • Can anyone confirm?
  • Does anyone know how to resolve this?
  • Is it possible to change the PID via IOS CLI?
Felix
Kindly find the link to the devices compatibility in the prime infrastructure 1.4.
http://www.cisco.com/en/US/products/ps12239/products_device_support_tables_list.html
CAP- models means controller bases access point (which is controlled by WLC)
To convert CAP to standalone AP. (example is shown below)
I am going to show you the easiest way...
you will need:
-CLI access to the unit
-TFTPd32
-ethernet cable
-dhcp (not really needed)
one you are on the unit..
the process will be:
debug lwapp console cli
debug lwapp client no-reload
archive download-sw /overwrite  tftp://10.0.0.1/c1130-k9w7-tar.124-10b.JDA3.tar
Hall of Fame Super Gold
Basant,
Your reply DOES NOT HELP.
Please READ & UNDERSTAND the OP's issue first.
Bronze
Re: Prime Infrastructure with autonomous AP AIR-CAP vs AIR-SAP
looks buggy to me... afaik PID can't be changed...
Suggest open tac case
1406
