Prime NCS: TACACS+ Integration into ACS 5.1
i'd like to integrate TACACS+ Integration into NCS.
I configured my ACS 5.1 correctly, but I get an "Access is denied to NCS" at the web login page. In the ACS i see a successful authentication.
Any ideas?
regards
Alex
Here is my Shell Profile Configuration
Hall of Fame Super Silver
How do you have your servie-type configured on ACS.  It should be set to login.
-Scott
Hi Scott,
thanks for your help,
it is set to Device Administration.
I can only choose Network Access, Device Administration and Radius Proxy
There is another setting somewhere in ACS to define the service type as login.  I will try to find it... might take some thime though, since I have to find a box to look at.
-Scott
I finally could log in, but not the default Ambassador view.
Thats really strange. Here is the authorization result from my ACS server.
{Type=Authorization; Author-Reply-Status=PassAdd; AVPair=role0=Lobby Ambassador; AVPair=task0=GLOBAL; AVPair=task1=Lobby Ambassador User Preferences; AVPair=task2=Basic; AVPair=task3=Configure Guest Users; AVPair=task4=Check License; AVPair=virtual-domain0=ROOT-DOMAIN; }
Is the username (lobby admin) also part of another group by chance?
-Scott
no, i started with an ACS user lobbyadmin, the last test i did where done with an active directory user called dersa. i mapped this user to an ACS User Group called NCS Lobby Ambassador.
I created also a shell profile for root, when i change the shell profile from NCS Lobby Ambassador to NCS Root Admin the user cannot log on anymore.
Re: Prime NCS: TACACS+ Integration into ACS 5.1
I’m going to have to see how I have it setup in my lab.
-Scott
Hi Alex,
What browser are you using ? If it's Internet Explorer, please install the "chrome frame" plugin & then try the login
Ram
i updated NCS to the latest release. It's working now. The problem was in the task list provided with the previous version. in the version the Task Lists were fixed.
thanks a lot for your support.
alex
I'm having the exact problem you had. I copied the TACACS tast list and setup the access policy, but the thing isn't functioning correctly. The task list I have is the following:
task0=Lobby Ambassador User Preferences
task1=Configure Guest Users
task2=License Check
I've also added the virtual domain to the list:
I'm current on the code rev. Is this your task list?
Doh! Answered my own question. Looks like the virtual domain needs to be first.
How do you integrate NCS to TACACS and use AD to define the "role". Do not want to have to create user in NCS in AAA, just use AD to authenticate the users that are already in a Group in AD.
Thanks much
You map a group to the role. I hope that makes sense.
Yes that's correct. You map the AD users to roles.
3917
