Printer not associating
I have a client with a printer that has a static IP and it is not associating with the WLC over FlexConnect.  For Debug Client all I see is
*apfMsConnTask_0: Jan 27 12:21:07.757: Association request from the P2P Client Process P2P Ie and Upadte CB
*apfMsConnTask_5: Jan 27 12:26:28.364: Association request from the P2P Client Process P2P Ie and Upadte CB
Nothing else. The IP is in the same subnet as the AP is it associating to, the key and SSID is correct, but that is all I see come across.
Can you change the printer to be DHCP and do a reservation for it's IP in the scope?
passive client is not supported with FlexConnect:
http://www.cisco.com/en/US/products/ps10315/products_tech_note09186a0080b3690b.shtml#anc12
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Yes, but if it does associate, what would prevent it from doing so with a static?   I will have the client set it to DHCP nad see if it connects.
Passive clients, like printers, tend to not send any IP information until they are triggered.  In Local mode AP, this is what Passive Client configuraiton helps with, to learn the static IP of clients that are not chatty.
With FlexConnect the AP will never be able to learn the client AP and install a bridge entry, as Passive Client is not supported
HTH,
Steve
Same results for DHCP, doesnt associate.
Hall of Fame Super Silver
Make sure that you have the lower data rates enabled... I have seen where disabling the lower data rates (good thing) breaks association with specific clients.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Data rates for that location are set to 1, 2, & 5.5 as mandatory.   What is strange is on the debug for that MAC I get two entires only, the request to associate, and nothing after that.
Going to call that printer V-ger.
yeah that is strange... don't know what else you can do unless the vendor has a work around.
Scott
-Scott
291
