Community Member
Problem installing/starting WCS 4.2.62.11 on Linux RH4
ls,
Is there someone with WCS 4.2.62.0 or 4.2.62.11 working on a RedHat Linux 4 system?
If so would you be so kind to mail me the output from next commando's:
rpm -qa
cat /etc/redhat-release
Starting WCS I got next failure:
Registry started.
Starting database server ...
Database server is running.
Starting NMS Server...
Exception in thread "main" java.lang.UnsatisfiedLinkError: /opt/WCS4.2.62.11/webnms/RFdlls/librfeng.so: Can't load IA 32-bit .so on a IA 32-bit platform
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(Unknown Source)
at java.lang.ClassLoader.loadLibrary(Unknown Source)
at java.lang.Runtime.loadLibrary0(Unknown Source)
at java.lang.System.loadLibrary(Unknown Source)
at com.cisco.server.map.RfPredictionServiceHelper.initialize(Unknown Source)
at com.cisco.server.map.RfPredictionServiceHelper.<init>(Unknown Source)
at com.cisco.server.map.RfPredictionServiceHelper.createInstance(Unknown Source)
at com.cisco.server.startup.NmsServer.initialize(Unknown Source)
at com.cisco.packaging.NMSMain.runMain(Unknown Source)
at com.cisco.packaging.NMSMain.main(Unknown Source)
It seems there is a problem somewhere in the shared objects. I'm running out of ideas.
Thanks in advance.
SU ICT / Ruud Kruitwagen
Hogeschool van Arnhem en Nijmegen
06-feb-2008
477
