Community Member
Problem with a lot of logins per user
We are using 2 (4 controllers) WiSM version 5.2.178.0 Controllers with WPA2/CCKM 802.1x EAP-MSCHAPv2 using freeradius v2 and eDirecvtory as backend.
About 500 1142 AP:s and 2400 clients.
The clients are running unmanaged Windows 7.
Clients are authenticating about 10- 20 times in a minute.
This causes heavy load on the Radius/eDirectory servers.
The clients having Atheros AT9285 wifi card without CCX support.
Our users also complains about having to reconnect frequently.
Any ideas how to reduce radius logins?
Henrik Hartelius
*Sep 14 16:37:59.825: c4:46:19:61:57:58 Unable to compute a valid PMKID from dot1x PMK cache for mobile c4:46:19:61:57:58
*Sep 14 16:37:59.825: c4:46:19:61:57:58 Found an entry in the global PMK cache for station c4:46:19:61:57:58
*Sep 14 16:37:59.825: CCKM: AA (6)
*Sep 14 16:37:59.825:      [0000] fc fb fb d8 7a a0
*Sep 14 16:37:59.825: CCKM: SPA (6)
*Sep 14 16:37:59.825:      [0000] c4 46 19 61 57 58
*Sep 14 16:37:59.825: c4:46:19:61:57:58 Unable to compute a valid PMKID from global PMK cache for mobile c4:46:19:61:57:58
*Sep 14 16:37:59.825: c4:46:19:61:57:58 85.188.98.23 RUN (20) Change state to START (0) last state RUN (20)
*Sep 14 16:37:59.825: c4:46:19:61:57:58 85.188.98.23 START (0) Initializing policy
*Sep 14 16:37:59.825: c4:46:19:61:57:58 85.188.98.23 START (0) Change state to AUTHCHECK (2) last state RUN (20)
*Sep 14 16:37:59.825: c4:46:19:61:57:58 85.188.98.23 AUTHCHECK (2) Change state to 8021X_REQD (3) last state RUN (20)
*Sep 14 16:37:59.825: c4:46:19:61:57:58 85.188.98.23 8021X_REQD (3) Plumbed mobile LWAPP rule on AP fc:fb:fb:d8:7a:a0 vapId 6 apVapId 1
*Sep 14 16:37:59.825: c4:46:19:61:57:58 apfPemAddUser2 (apf_policy.c:210) Changing state for mobile c4:46:19:61:57:58 on AP fc:fb:fb:d8:7a:a0 from Associated to Associated
Re: Problem with a lot of logins per user
If the client does not use CCX, then you should not be using CCKM as the keying method, you should use 802.1x.  But from what I am seeing, the client is not sending a valid PMK, so we can't fast roam them, they have to do a full AAA authenticaiton.  My other normal suggestion would be to check for updated drivers but as they are "unmanaged, this may not be feasible
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
I have checked 802.1x and CCKM under Wlan security, is that a problem?
It seems like the clients are roaming a lot, and what I understand, if I don't have CCXv4 support on the clients,
CCKM don't working and the client have to do a full 802.1x authentication including radius requests, whenever it's roaming. I'm I right?
411
