Problem with ap's, appears in disable state in WLC.
Hi all,
I have two Wism2 in central site, I have asociated in those Wism2 the local and remote ap's in my company, some ap's are asociated in Wism2-1 (i-e) and some others in wism2-2. And all are configured to high availability between two controllers.
Ok, the issue is this, four of my app's in remote site appears sometimes like disabled when I check in Wism the Controller>all ap's (ap name) in admin status this appears like disabled, the ap's aren't disassociated, only appears disabled, but you can check into ap, credentials, inventory, flex connect, etc...
I suspect the problem might be the high delay of link between remote site and central site, so it I enable link latency in this four ap's, the link latency show me minimun, average and high latency in my link.
Link Latency
Data Latency
I don't know in deep what is the behavior of the ap's respect to WLC/Wism when the link latency is very high.
Can you help me, please?
Thank in advance.
Best regards.
1 REPLY
Ok, the link latency values doesn't appear.
The value of latency are those:
                               Current (mSec)          Minimum (mSec)          Maximum (mSec)
Link Latency                                        229                                                  219                                        1601
Data Latency                                        <1                                                       <1                       <1
Sorry for the mistake.
BR.
172
