Problem with registration Access point on WLC
I have wlc AIR-WLC2112-K9 and eight ap AIR-LAP1231G-E-K9   , but one ap won't register and he worked just fine for some time.
WLC supported 12 access points.
error log :
*Mar  1 00:00:04.468: %SOAP_FIPS-2-SELF_TEST_IOS_SUCCESS: IOS crypto FIPS self test passed
*Mar  1 00:00:05.744: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 0
*Mar  1 00:00:07.301: %SOAP_FIPS-2-SELF_TEST_RAD_SUCCESS: RADIO crypto FIPS self test passed on interface Dot11Radio 1
*Mar  1 00:00:07.359: %LWAPP-3-CLIENTEVENTLOG: Read and initialized AP event log (contains, 927 messages)
*Mar  1 00:00:07.386:  status of voice_diag_test from WLC is false
*Mar  1 00:00:08.411:  STUB Called : crypto_ssl_init
*Mar  1 00:00:09.455: %LINK-3-UPDOWN: Interface FastEthernet0, changed state to up
*Mar  1 00:00:09.500: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C1200 Software (C1200-K9W8-M), Version 12.4(23c)JA2, RELEASE SOFTWARE (fc3)
Copyright (c) 1986-2011 by Cisco Systems, Inc.
Compiled Wed 13-Apr-11 12:55 by prod_rel_team
*Dec 22 17:14:48.097: %CAPWAP-5-CHANGED: CAPWAP changed state to DISCOVERY
*Dec 22 17:14:48.142: %LWAPP-3-CLIENTERRORLOG: LWAPP Crypto Init (SSC): no certs in the SSC Private File
*Dec 22 17:14:48.145: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 22 17:14:48.145: %LINK-5-CHANGED: Interface Dot11Radio1, changed state to reset
*Dec 22 17:14:48.209: %LINK-3-UPDOWN: Interface Dot11Radio1, changed state to up
*Dec 22 17:14:48.215: %LINK-5-CHANGED: Interface Dot11Radio0, changed state to reset
*Dec 22 17:14:48.225: %LINK-3-UPDOWN: Interface Dot11Radio0, changed state to up
*Dec 22 17:14:48.952: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0, changed state to up
*Dec 22 17:14:49.144: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio0, changed state to up
*Dec 22 17:14:49.144: %LINEPROTO-5-UPDOWN: Line protocol on Interface Dot11Radio1, changed state to up
*Dec 22 17:14:56.268: %DHCP-6-ADDRESS_ASSIGN: Interface FastEthernet0 assigned DHCP address 10.11.11.152, mask 255.255.0.0, hostname AP0014.6a91.b579
Writing out the event log to nvram...
*Dec 22 17:15:06.913: %LWAPP-3-CLIENTERRORLOG: LWAPP Crypto Init: could not start PKI session
*Dec 22 17:15:06.913: %LWAPP-3-CLIENTERRORLOG: Failed to initialize Crypto. Rebooting
*Dec 22 17:15:06.955: %SYS-5-RELOAD: Reload requested by CAPWAP CLIENT. Reload Reason: FAILED CRYPTO INIT.
*Dec 22 17:15:06.956: %LWAPP-5-CHANGED: CAPWAP changed state to DOWNXmodem file system is available.
flashfs[0]: 11 files, 3 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 7741440
flashfs[0]: Bytes used: 5380096
flashfs[0]: Bytes available: 2361344
flashfs[0]: flashfs fsck took 14 seconds.
Reading cookie from flash parameter block...done.
Base ethernet MAC Address: 00:14:6a:9*****
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
ethernet link up, 100 mbps, full-duplex
Ethernet port 0 initialized: link is up
Loading "flash:/c1200-k9w8-mx.124-23c.JA2/c1200-k9w8-mx.124-23c.JA2"...##################################################################################################################################################################################################
File "flash:/c1200-k9w8-mx.124-23c.JA2/c1200-k9w8-mx.124-23c.JA2" uncompressed and installed, entry point: 0x3000
executing...
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Proceeding with system init
Proceeding to unmask interrupts
Initializing flashfs...
flashfs[1]: 11 files, 3 directories
flashfs[1]: 0 orphaned files, 0 orphaned directories
flashfs[1]: Total bytes: 7483392
flashfs[1]: Bytes used: 5382144
flashfs[1]: Bytes available: 2101248
flashfs[1]: flashfs fsck took 2 seconds.
flashfs[1]: Initialization complete....done Initializing flashfs.
Radio0  present A506 5100 E8000000 A0000000 80000000 3
Radio1  present A506 6700 E8000100 A0040000 80010000 2
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
cisco AIR-LAP1230B-E-K9     (PowerPC405GP) processor (revision A0) with 15038K/1336K bytes of memory.
Processor board ID FHK0*****
PowerPC405GP CPU at 196Mhz, revision number 0x0145
Last reset from power-on
LWAPP image version 7.0.116.0
1 FastEthernet interface
2 802.11 Radio(s)
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 00:14:6A:*****+
Part Number                          : 73-8704-09
PCA Assembly Number                  : 800-23211***
PCA Revision Number                  : A0
PCB Serial Number                    : FOC*******
Top Assembly Part Number             : 800-2330***
Top Assembly Serial Number           : FHK*******
Top Revision Number                  : A0
Product/Model Number                 : AIR-AP1230B-E-K9
% Please define a domain-name first.
no ip http server
% Invalid input detected at '^' marker.
VIP Purple
Hi,As per your logs:*Dec 22
As per your logs:
You must add the SSC and its MAC address under the AP Authentication list in the controller.
Check the cause number 8 in this doc :
http://www.cisco.com/c/en/us/support/docs/wireless-mobility/wireless-lan-wlan/69339-lwapp-upg-tool.html
add ssc to wlc:
http://www.cisco.com/c/en/us/support/docs/wireless/4400-series-wireless-lan-controllers/70341-manual-add-ssc.html#add
Hope it helps.
Dont forget to rate helpful posts
hi , thanks for reply. When I
When I try to add AP to Authorization List. I don't now value for SHA1 Key Hash . Picture is in attachment.
VIP Purple
Hi,You can locate the SHA1
You can locate the SHA1 Key Hash:
you can issue a debug command on the WLC in order to retrieve the SHA1 Key Hash.
Complete these steps:
Turn on the AP and connect it to the network.
Enable the debugging on the WLC command-line interface (CLI).
The command is debug pm pki enable.
For complete guide check this:
177
