Problems with the Wireless Web GUI cisco 3850
Hello everybody, this is the problem I'm having with C3850 switch.
When i try to configure the wireless lan controller wizard using Chrome or Internet Explorer  I can not submit any changes. Also when I try to change the name or the RF group name and other things. I think that the real problem is that, when I try to access to the browser (Chrome or Internet explorer) using the switch IP returns me a certificate error. I always dismiss this issue and enter the site anyways. I think that this is is not allowing me to do important changes on the configuration of WLC. If anyone have a solution would be great.
1 ACCEPTED SOLUTION
VIP Purple
Hi GUI of these controller
GUI of these controller still not their best or reliable as well, so I always use CLI for the configuration. Make sure you use IOS-XE 3.6 to get whatever the GUI enhancement this product has.
If you looking for specific commands to configure a feature let us know, otherwise for general config below should helps you.
1. http://mrncciew.com/2013/09/29/getting-started-with-3850/
2. http://mrncciew.com/2013/12/04/wlan-config-in-3850-part-1/
3. http://mrncciew.com/2013/12/06/wlan-config-with-3850-part-2/
4. http://mrncciew.com/2013/12/14/3850ma-with-5760mc/
5. http://mrncciew.com/2014/08/05/client-details-in-converged-access/
Rasika
*** Pls rate all useful responses ****
VIP Purple
Rasika
Hi ,The error is because of
Hi ,
The error is because of the fact that your browser doesnt trust the certificate produced by the 3850 switch.
For 5760 , you can rely on GUI but for 3850 , either rely on command line.
Dhiresh
Try to use CLI if you don't
Try to use CLI if you don't rely on the Certificate.
192
