Problems with VLAN trunk between Aironet 1231 and HP switch
Hi.
I am helping a customer with setting up multiple SSIDs on their wireless APs. I have created two SSIDs which use different VLANs. There is also a third VLAN for management. Everything works fine when connected to a trunk port on a Cisco switch. The customer, however, has HP switches, and I am not getting the trunk port to work there. Do you know if I need to configure anything different on the AP when using an HP switch?
AP conf:
hostname wpa-test
enable secret xxxxxx
aaa new-model
aaa group server radius rad_eap
server x.x.x.x auth-port 1645 acct-port 1646
aaa authentication login eap_methods group rad_eap
aaa authorization exec default local
aaa session-id common
dot11 ssid Personal
   vlan 4
   authentication open eap eap_methods
   authentication key-management wpa
   guest-mode
   mbssid guest-mode dtim-period 75
dot11 ssid Public
   vlan 3
   authentication open
dot11 aaa csid ietf
username Cisco password xxxxxxxx
bridge irb
interface Dot11Radio0
no shutdown
no ip address
no ip route-cache
encryption vlan 4 mode ciphers tkip
encryption mode ciphers tkip
ssid Personal
ssid Public
mbssid
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.4
encapsulation dot1Q 4
no ip route-cache
bridge-group 4
bridge-group 4 subscriber-loop-control
bridge-group 4 block-unknown-source
no bridge-group 4 source-learning
no bridge-group 4 unicast-flooding
bridge-group 4 spanning-disabled
interface Dot11Radio0.3
encapsulation dot1Q 3
no ip route-cache
bridge-group 3
bridge-group 3 subscriber-loop-control
bridge-group 3 block-unknown-source
no bridge-group 3 source-learning
no bridge-group 3 unicast-flooding
bridge-group 3 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 12 in
interface FastEthernet0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 1
interface FastEthernet0.4
no ip route-cache
bridge-group 4
interface FastEthernet0.3
no ip route-cache
bridge-group 3
interface BVI1
ip address x.x.x.x 255.255.255.0
no ip route-cache
ip default-gateway x.x.x.x
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
radius-server attribute 32 include-in-access-req format %h
radius-server host x.x.x.x auth-port 1645 acct-port 1646 key xxxxxxxxxxxxx
radius-server key xxxxxxxxxxxx
radius-server vsa send accounting
bridge 1 route ip
wlccp wds aaa csid ietf
line con 0
line vty 0 4
end
HP switch conf
1# show running-config
Running configuration:
; J4903A Configuration Editor; Created on release #I.10.101
hostname "1"
time timezone 60
time daylight-time-rule Western-Europe
exit
sntp server x.x.x.x
timesync sntp
sntp unicast
snmp-server community "nonono" Unrestricted
snmp-server community "public" Operator Unrestricted
vlan 1
   name "DEFAULT_VLAN"
   no ip address
   no untagged 1-24
   exit
vlan 2
   name "HK"
   untagged 1,5-24
   tagged 4
   exit
vlan 3
   name "Public"
   untagged 2
   tagged 4
   exit
vlan 4
   name "Personal"
   untagged 3
   tagged 4
   exit
spanning-tree
password manager
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Problems with VLAN trunk between Aironet 1231 and HP switch
Well the AP management should be untagged and should be defined as native on the AP.
-Scott
The AP is the same, which basically means that the only untagged vlan should be the management of the AP. The other vlans need to be tagged. I have had issues in the past with HP switches and I'm not an expert in those... I had to make sure that I defined the try k port vlan properly before it started working. I would ask around on the HP side of the house.
-Scott
Currently all VLANs are tagged, on both sides. I have asked on HP forums as well.
-Scott
Don't understand why, but it seems to work when the management VLAN is untagged/native.
This is the default and only way to configure autonomous access points.  Management requires to be untagged.  Glad you got it working.
Scott
Help out other by using the rating system and marking answered questions as "Answered"
-Scott
Here is a link sort of expalining it:
http://www.cisco.com/en/US/tech/tk722/tk809/technologies_configuration_example09186a0080665ceb.shtml#native
Scott
-Scott
950
