06-14-2007 03:31 AM - edited 07-03-2021 02:13 PM
we want to upgrade our WLCs from version 4.0.217 to 4.1.171. Two WLCs are now already upgraded, but we had problems to upload the new firmware to the WLC. We are worked with the CLI and used the "TFPD32" programm.
The upload of the new software breaks several times down, after 20 or 30 attempts the upload are completed.
This errors messages are displayed in the TFPD32:
Ack block 108 ignored (received twice) [04/06 15:56:17.288]
File <AIR-WLC4400-K9-4-1-171-0.aes> : error 10054 in system call recv An existing connection was forcibly closed by the remote host. [04/06 15:56:17.288]
Mit freundlichen Gruss
Andre Schroeder
06-14-2007 07:07 AM
Did you put the 4.1.171ES image on 1st per the release notes?
06-14-2007 07:46 AM
in the release notes are written:
4.0.206.0 or later 4.0 release
--> You can upgrade directly to 4.1.171.0.
We want to upgrade from version 4.0.217.0 to the 4.1.171.0.
Andre Schroeder
06-14-2007 07:52 AM
The ES is the boot image for the OS.
AIR-WLC4400-K9-4-1-171-0-ER.aes
Cisco Unified Wireless Network Controller Boot Software 4.1 for Cisco 4400 series Wireless LAN Controllers 4.1.171.0 30-APR-2007 4192676
Cisco Unified Wireless Network Software Release 4.1 for Cisco 4400 Series Wireless LAN Controllers. 4.1.171.0 30-APR-2007 33600312
You need both. Place the boot image on 1st, then the OS image
06-14-2007 07:56 AM
Found this in the rel notes as well on page 4
? Due to some critical enhancements that were made to the bootloader software for the Cisco WiSM,
Catalyst 3750G Wireless LAN Controller Switch, and 4400 series controllers, you must install the
Cisco Unified Wireless Network Controller Boot Software 4.1.171.0 _ER.aes image either before
or after installing the 4.1.171.0 .aes file. You can obtain these files from the Software Center on
Cisco.com and install both of them using the software upgrade instructions provided in the Cisco
Wireless LAN Controller Configuration Guide, Release 4.1. For additional information on the
Controller Boot Software, refer to the ?Using the Cisco Unified Wireless Network Controller Boot
Software 4.1? section on page 13.
So, I guess order is not that important.
06-14-2007 08:16 AM
we are done the following steps:
1. upload boot image
2. reboot WLC
3. upload OS --> here we have the problems
Andre Schroeder
06-14-2007 09:16 AM
I have used the basic tftp-server that is available with many linux distros without any issue.
Perhaps you are hitting the 16mb limit of the 3com server. Here is more info on Cisco & tftp
http://www.ciscoblog.com/archives/2007/01/new_and_improve.html
06-14-2007 10:58 PM
therfor we are used the programm "tftpd32".
Andre Schroeder
06-15-2007 08:26 AM
Can you ssh to your controller and bump up
the tftpPktTimeout & tftpMaxRetries values?
transfer download tftpPktTimeout
transfer download tftpMaxRetries
and then try it
06-18-2007 04:06 AM
we done the update in the cli and changed also the timeouts and retries (from WLC and TFTP tool) - but without success.
Andre Schroeder
06-18-2007 05:27 AM
Where is the tftp server in relation to the WLC?
is it in the same subnet or across a slow wan link...
It sounds like it is a general network performance issue than an issue with the WLC units.
Have you tried using the WCS as the tftp server?
If you have network issues, it should affect WLC/WCS communications as well.
06-21-2007 04:30 AM
we have to done the update in the following sequence:
1. upload firmware (OS)
2. reboot
3. upload bootcode
4. reboot
With this sequence, we had no problems.
Andre Schroeder
