Protecting from DHCP Pool exhaustion
We are looking to allow the iPad/iPhone devices on the network.  From reading previous reports in the media, I know that several colleges/universities have run into a problem with some code versions not handling DHCP correctly.
I am looking at trying to protect us from a DHCP Pool exhaustion situation.  We have implement some of the port security commands.  On the trunk ports that the AP's are connected to, I have used ip arp inspection trust  as a default.  Maybe we need to look at changing that stance.  Putting this command on all trunk ports, whether connected to an AP or a switch, is what we do as a part of our normal deployment.
Suggestions ?
1 REPLY
Re: Protecting from DHCP Pool exhaustion
Are you also utilizing the dhcp snooping feature?  In a college environment we had to implement this on our campus switches.
http://www.cisco.com/en/US/docs/solutions/Enterprise/Mobility/emob30dg/SecInteg.html#wp1005858
-Rick
311
