Qos Roles
rluyster
When adding a guest user with a lobbyadmin id, is it possible to assign that user a QoS role.
krengasw
This feature QOS roles for guest user using lobby admin was supported on wcs .yes,you are right,this qos role for guest user using lobby was not implemeted on controller side.
8 Replies 8
Scott Fella
You only can assign an ssid tto a QoS level.
-Scott
I have assigned the QoS policy to the SSID, however f I add a "guest account" with an admin account, it allows to to select "guest user role" and assign the QoS role that I have defined. When using the LobbyAdmin account this option is not there and the user is only limited to the QoS policy defined on the SSID. My thought was to create seperate roles and futher limit bandwidth depending on what the guest role was.
What code are you running?
-Scott
4.2.61
Have you verified that it takes the QoS level you set when you are logged in as an administrator. I'm wondering if this overrides the SSID Qos level or not.
-Scott
I have verified this, and yes it does override the SSID levels.
Nice to know.... Well since the Lobby Admin doesn't have this feature, you can always let your local wireless SE to put this as a future feature request.
-Scott
krengasw
