Question about AP-SSO
Hi everybody:
I have a client who has installed two WLCs in a AP-SSO mode
They have tested the alarms when something critical occur in the active peer, like an interface disconnected
But they are compliant because can't see any alarm if something critical occur in the standby peer
Is this a normal behavior?
This HA system is new for me, but I know the ASA active/standby system and in that case you can monitorize the status of each interface
Are there something similar in AP-SSO?
Do you realize what happen if an interface is down in the standby peer and the active peer fail?
Any comment will be appreciated
Thanks in advance
Al
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Question about AP-SSO
Currently there isn't a way. If you search around the forum, others have also complained about notification and how to monitor the HA pair. Maybe one day is all I can say.
-Scott
-Scott
Hi Scot
I'm sorry, I didn't see the other post about this subject
Thank you very much
Al
139
