Question about CISCO1921-SEC/K9 license
I've purchased a used CISCO1921-SEC/K9 and I'm trying to figure out if I got what I paid for. The specifically purchased this unit because I wanted to take advantage of the SEC package for VPN.
I looked at the show run and I'm not seeing anything about SEC/K9. The following is what I see:
Router#sh run
license udi pid CISCO1921/K9 sn xxxxxxxx
Router#sh license feature
Feature name             Enforcement  Evaluation  Subscription   Enabled
ipbasek9                 no           no          no             yes
securityk9               yes          yes         no             no
datak9                   yes          yes         no             no
SSL_VPN                  yes          yes         no             no
ios-ips-update           yes          no          yes            no
Router#sh license all
License Store: Primary License Storage
StoreIndex: 0   Feature: ipbasek9                          Version: 1.0
        License Type: Permanent
        License State: Active, In Use
        License Count: Non-Counted
        License Priority: Medium
License Store: Evaluation License Storage
StoreIndex: 0   Feature: securityk9                        Version: 1.0
        License Type: Evaluation
        License State: Active, Not in Use, EULA not accepted
            Evaluation total period: 8  weeks 4  days
            Evaluation period left: 8  weeks 4  days
        License Priority: None
StoreIndex: 1   Feature: datak9                            Version: 1.0
StoreIndex: 2   Feature: SSL_VPN                           Version: 1.0
        License Count: 75/0/0  (Active/In-use/Violation)
I'm I right by assuming that this unit doesn't have the Security license? It looks to me like it has an 8 week trial of the license. I want someone else to verify this before I contact the seller.
Thanks.
Hall of Fame Super Gold
Re: Question about CISCO1921-SEC/K9 license
Send an email to license@cisco.com.
According to your output, IP Base is the only one that's activated.
Sent from Cisco Technical Support Wii App
I know but my main question was whether the device I bought had a SEC license or not. I don't have experience with CISCO licensing and that's why I'm asking what might seem like a stupid question. The person I bought the unit from, said it included the license for sec but with my untrained eyes, I don't see it. I see an 8 week trial for security and I wanted to verify that I was reading that right.
I will contact the seller if my assumptions are right.
This is why I'm asking you to send an email to licence@cisco.com.
Your router currently have IP Base licence.  If licence@cisco.com determines that you indeed pay for of a SEC license and you got the wrong feature set activated, it can be easily fixed when Cisco sends you the activation key.  It's now that simple.
Re:Question about CISCO1921-SEC/K9 license
You only have ipbasek9 license...
Sometimes, Kind of contract with PAK number come with the device and you need to get use this number to get .lic file on cisco.com/go/license
Last.chapter on below pdf
https://www.cisco.com/en/US/docs/routers/access/1900/hardware/installation/guide/1940_HIG.pdf
Sent from Cisco Technical Support Android App
Thanks for the help but the email address you provided doesn't work. license@cisco.com bounces back.
Try licensing@cisco.com.
Hi,Benso2013You can follow
Hi,Benso2013
You can follow this article to know which license suitable for CISCO1921-SEC/K9. Wish this help you.
6457
