Community Member
question about wireless ethernet traffic
Im sniffing wireless packets and seeing something I don't understand and cannot find relevant documentation on....
In the 802.11 wireless lan management frame, tagged parameters section I am seeing a Tag number 133 which is listed as a reserved tag number, with a value that LOOKS like an SSID. But is not in fact the ssid, as broadcast-ssid is not enabled on this AP and the SSID tag field length is shorter than this piece of data.
Can anyone help me
1. decipher the meaning of tagged paremeter 133
2. point me in the direction of documentation that will break out each tagged parameter and its meaning and values?
Re: question about wireless ethernet traffic
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center ( or speak with a TAC engineer. You can open a TAC case online at
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
