Question regarding Cipher suite and ACS
Hello all,
I have a few of AP 1200s, a ACS box and a few of laptop. I am trying to build a wireless network in a test environment for a better security. Is Dynamic WEP 128 bit with TKIP in Cipher suite the best option so far? What are other options? Pros and cons? How do I config ACS to do DWEP 128 bit? Do I need a router or AD (active directory)? Since it is DWEP, how should I config those laptops? Are there any software can go out to config all those laptops at once?
I really appreciate any helps on the above subjects and questions.
thanks,
Gene
1 REPLY
Silver
115
